Discussion topic: Nothing from sky q box
This message was authored by: Minxorcist
Hi, just turned on my Sky Q box, all I see is a screen of snowy static. That's it. Nothing else ☹️
Any ideas of the problem anyone? I've only had it around 6 week. Dish and all connections are good.
Re: Nothing from sky q box
Such a screen is where the HDCP has not negotiated a connection.
Try turning your TV off and back on again, check all HDMI connections.
Avatar for Minxorcist
@PandJ2020
Thanks for helping. I turned the whole lot off at the wall, waited five mins, and turned them back on again. All good now 👍🏻😊
