Discussion topic: Not working
This message was authored by: Claremcnic
Not working
White wire been pulled from main sky box = loss of channels also need new multi room equipment. May need an engineer
Re: Not working
What is the white cable? The one from the dish? Has it been pulled out of the plug and left that screwed into the box? It's not difficult to reattach the plug to that coax cable but turn the box off first then unscrew the f-plug and put it back on the cable as per
https://youtu.be/jjMiCgyeFm4?si=295aeHdaQYZFm9wg
is the "new multiroom equipment" additional or replacing something broken?
