Discussion topic: Not working
This message was authored by: Frances3454
Not working
My sky box (mini) hasn't worked in two months or more! I have tried several times to connect it to the main box but it will not pick up a signal. Yet I'm still being billed and haven't been able to watch sky for months. Can someone please help me as every time I ring I get cut off or told to use this service.
Re: Not working
Hi @Frances3454 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with the Mini box?
Avatar for Frances3454
Re: Not working
Thank you, I'll try this in morning. Hopefully it'll work 👍🏼
