1
This discussion topic has been answered Discussion topic: Not working
This message was authored by: Sharonmcmahon
Not working
This message was authored by: nigea99 Answer
Re: Not working
hi @Sharonmcmahon
From the images you have posted it looks like there is no power on the mini.
I suggest checking the power cable, and maybe try changing the fuse in the plug (should be a 3A)
As they use a standard figure of 8 cable is it possible to try a similar cable from another device you might have ?
Re: Not working
hi @Sharonmcmahon
Answered - Go to Answer
