Discussion topic: Sky q boxes both will not connect to the broadband router. Done all trouble shooting , need new boxe
Message posted on 30 Sep 2023 11:07 AM
Started 4 days ago my sky boxes kept dripping Wi-Fi connection then would not connect to each other. I have main sky q box in the kitchen and 1 multi room that's in my main lounge . Today they both can not connect to the router at all. They can see my broadband just can't connect
Message posted on 30 Sep 2023 11:11 AM
Re: Sky q boxes both will not connect to the broadband router. Done all trouble shooting , need new
Have you carried out a Network reset on your main Q box exactly as follows:-
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
