Discussion topic: Not connecting
Message posted on 29 Dec 2023 09:44 AM
Not connecting
Sky mini box not connecting
Message posted on 29 Dec 2023 09:45 AM
Re: Not connecting
Mini box not connecting
Message posted on 29 Dec 2023 12:23 PM
Re: Not connecting
@D-stan2020 Have you tried rebooting your main Q box ie
then
reboot your mini box
Message posted on 29 Dec 2023 12:30 PM
Re: Not connecting
Hi @D-stan2020
Try a Network Reset on the mini.
