29 Dec 2023 12:29 PM
When watching films on second tv with small skt box (secondary to main skyq box) films regularly buffer and pixillate
29 Dec 2023 12:33 PM
Hi @DWL2012
Reboot the mini as above.
29 Dec 2023 12:42 PM
Cheers, i'll give that a try
