Discussion topic: Noise q box
This message was authored by: Louise131
Noise q box
Engineer changed q box to help with a situation....now the box is so noisy and can hear it constantly....the other box didn't make this noise.....
This message was authored by: Padam_Padam
Re: Noise q box
Some Sky Q boxes are noisier than others. If it's too distracting then contact Sky and ask for another replacement until you get a decent one.
This message was authored by: bemak187
Re: Noise q box
@Louise131  All Sky Q boxes make noise.  The hard drive is basically active all the time.  Some make more noise then others.
This message was authored by: Cuke2u
Re: Noise q box
That isn't quite correct as in standby our box is silent. I suggest @Louise131 tries for a replacement as @Padam_Padam suggests..
