Discussion topic: Sky won’t come on
This message was authored by: EllenO1
Sky won’t come on
this is my second attempt to explain that initially a film I had skyplussed froze & wouldn't let me do anything. Knocked the tv off for a few hours, now sky is blank, can't access any channels or recording
Re: Sky won’t come on
You've posted in the Sky Q forum, but you mention Sky+. Which do you have?
Avatar for EllenO1
Level 0 icon
SkyQ I believe
Try rebooting your Q box @EllenO1
If you had to press the Standby button on the Q box to bring it on then try completly resetting your Bluetooth remote.  (Q box must be on with green led)
