Discussion topic: No tv schedule
Message posted on 10 Apr 2025 05:14 PM
No tv schedule
Can't get tv schedules
Message posted on 10 Apr 2025 05:19 PM
Re: No tv schedule
Hi @Dochp Have you tried power rebooting your Sky Q Main box?
Message posted on 10 Apr 2025 05:30 PM
Re: No tv schedule
@Dochp
So, as suggested try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
