This discussion topic has been answered Discussion topic: No tv on sky mini boxes
Message posted on 11 May 2024 09:49 PM
both of our 2 sky mini boxes show a message of please check your subscription entitles you to view this channel on this box.
it happens on every channel, our main sky box is fine. I contacted sky and the said an engineer will need to come out and 'enter a code' but the earliest engineer appointment is 27th May! That's ridiculous! Bet they would be able to get someone out quicker for a new install!!
any suggestions?
Message posted on 12 May 2024 08:18 AM
Hi there! Thank you for escalating this. We have sent an invite to @Kevin572.
Message posted on 11 May 2024 09:52 PM
Re: No tv on sky mini boxes
any suggestions?
Hi @Kevin572
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Message posted on 11 May 2024 09:58 PM
Thanks @oldfella i have already tried all of your suggestions several times but had no luck!!
Message posted on 11 May 2024 10:01 PM
Hi @Kevin572
When the main Q box is back up and running reboot the minis again
Message posted on 11 May 2024 10:07 PM
@oldfella I had actually already seen this suggestion on another thread and so I have also already tried this, with no luck!!
Message posted on 12 May 2024 06:29 AM
Sounds like you have tried the box reboots and resets.
I've escalated this to Sky and they should be in touch with you soon about it.
Look out for a message from Sky on your email and Sky Community private messages.
Look out for the blue chat bubble within your Sky community.
More about an escalation here;
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
