Discussion topic: No tv channels
Message posted on 28 Feb 2024 05:49 PM
No tv channels
I have lost all my tv channels
Message posted on 28 Feb 2024 05:51 PM
Re: No tv channels
Whenever a “no satellite signal” message is displayed like you have firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye and could only affect one or two channels). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
