Discussion topic: No sound
This message was authored by: JamesRavenhall
Message posted on 09 Apr 2024 07:58 PM
No sound
No sound via sky. When I go to other app on my smart TV I get sound. I have gone through the hep section and reset, but now the remote for the sky box does not work.
Find out more
Message posted on 09 Apr 2024 08:05 PM
Re: No sound
If you have reset your box, you probably need to reset your remote & re-pair it.
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
