Discussion topic: No sound!
Message posted on 10 Sep 2023 04:16 PM
No sound!
Sky Q has no sound, was working fine this morning now nothing. Changed HDMI still no sound. Any ideas?
Message posted on 10 Sep 2023 04:18 PM
Re: No sound!
Hi @Simonbibs
Assume you have tried rebooting your Q box.
If you have and it hasn't solved your issue
Message posted on 22 Oct 2023 07:37 PM
Re: No sound!
Hi, I have no sound on my main Sky Q box
1. I've rebooted
2. I've tried a software update
3. I've done a reset
4. The miniboxes seem to be ok
5. It's no sound on anything, TV, recordings Apps.
6. TV sound itself is fine.
Help!
Message posted on 22 Oct 2023 07:57 PM - last edited: 22 Oct 2023 07:57 PM
Re: No sound!
1. I've rebooted
Help!
hi @Anonymous
Have you tried doing a power down restart of your TV.
Some people find that this does restore sound when they have lost it (even if the sound is working for other sources)
Message posted on 22 Oct 2023 09:40 PM
Re: No sound!
Yes. Point 1.
Message posted on 22 Oct 2023 09:48 PM
Re: No sound!
@Anonymous wrote:Yes. Point 1.
Have you set audio to Normal instead of Dolby?
Message posted on 04 Nov 2023 06:50 PM
Re: No sound!
This worked for me! Turned the TV off from the plug and the sound was restored.
Message posted on 08 Mar 2024 12:20 AM
Re: No sound!
Same issues as above, tried reboot, reset, firmware upgrade-nothing.
My sound is played through a reciever, o the TV is merely a monitor, yet unplugging the Tv for a while reste the sound on the SkyQ box, strange...but thank you.
Message posted on 07 Jun 2024 04:05 PM
Re: No sound!
Hi!
try this as it worked for me:
go into YouTube from the apps menu and play any video when the sounds comes on.
exit the app and then the sound will be back.
