Discussion topic: No sound!
This message was authored by: Simonbibs
No sound!
Sky Q has no sound, was working fine this morning now nothing. Changed HDMI still no sound. Any ideas?
Re: No sound!
Hi @Simonbibs
Assume you have tried rebooting your Q box.
If you have and it hasn't solved your issue
This message was authored by: Dagaffer
Re: No sound!
Hi, I have no sound on my main Sky Q box
1. I've rebooted
2. I've tried a software update
3. I've done a reset
4. The miniboxes seem to be ok
5. It's no sound on anything, TV, recordings Apps.
6. TV sound itself is fine.
Help!
Re: No sound!
1. I've rebooted
Help!
hi @Dagaffer
Have you tried doing a power down restart of your TV.
Some people find that this does restore sound when they have lost it (even if the sound is working for other sources)
Re: No sound!
Yes. Point 1.
This message was authored by: Invisiblename
Re: No sound!
@Dagaffer wrote:
Yes. Point 1.
Have you set audio to Normal instead of Dolby?
I am just another Sky customer!
This message was authored by: psem
Re: No sound!
This worked for me! Turned the TV off from the plug and the sound was restored.
This message was authored by: corpcab
Re: No sound!
Same issues as above, tried reboot, reset, firmware upgrade-nothing.
My sound is played through a reciever, o the TV is merely a monitor, yet unplugging the Tv for a while reste the sound on the SkyQ box, strange...but thank you.
This message was authored by: Bridget123
Re: No sound!
Hi!
try this as it worked for me:
go into YouTube from the apps menu and play any video when the sounds comes on.
exit the app and then the sound will be back.
