04 Aug 2023 07:36 PM
No sound on Sky TV. Checked connections mute etc. Netflix and iplayer work
unplugged connections turned power off etc
04 Aug 2023 07:46 PM
Hi @Afrikaans
Have you tried changing the HDMI audio output in Settings?
ie tried Normal and Dolby Digital in Home - Settings - Setup - Audio Visual.
Failing this
04 Aug 2023 08:06 PM
Didn't work.
04 Aug 2023 08:14 PM
Posted by a Superuser, not a Sky employee. Find out morehi @Afrikaans
If you haven't aready tried, try a full power down restart of your TV
We sometimes find this restores sound for people reporting loss of it.
04 Aug 2023 08:19 PM
Yes tried that
01 Nov 2023 10:09 PM
No sound on my SkyQ main box although fine on mini boxes? Sound on Apple Tv and normal tv is normal - just no sound at all on sky Q. Have tried rebooting and resetting - still nothing.
18 Dec 2023 09:24 AM
Hi, I have this same problem. Did you get a fix in the end?
