Discussion topic: No sound when hd selected
This message was authored by: Robert1952
To use my headphones i have to connect a toslink cable and dac convertor, to th sky q box. every thing works then other than hd channels. Is there a way round this please.
Re: No sound when hd selected
hi @Robert1952
HD channels use Dolby Digital - if your set up cannot handle this set the output to Normal
Home - Settings - Setup - Audio Visual
Digital audio output HDMI
Hi @Robert1952
As you are using the Optical audio output for your toslink cable it the Optical Audio out settings in you Q box that you need to set to Normal.
Q Home menu - Settings - Setup - Audio Visual.
Set Optical Audio out to Normal
@oldfella wrote:
Hi @Robert1952
oops - I should have mentioned that setting as well as this is more likely for this
