Discussion topic: Says no satellite signal or technical problem. A few channels still.work as do.apls oike netflix et
This message was authored by: Karl2
My sky  some channels say no satellite signal or there us a technical issues. Some channels work like channel 4 but most don't. Was working fine yesterday evening but not since toast night. Tried turning off and unplugging etc but no luck
Re: Says no satellite signal or technical problem. A few channels still.work as do.apls oike netflix
@Karl2
Not sure what toast night has to do with it 😀 but if it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
@Karl2  Work through this link https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-live-tv/no-satellite-signal/articl...
At the end if not resolved it should allow you to book an engineer.
