Discussion topic: No sound on Qbox
Message posted on 07 Jul 2023 12:19 PM
No sound on Qbox
I've suddenly got no sound from sky Q. I've reset the box I've swapped the HDMI leads and tried HDMI in a different input. All settings look correct. Sound on TV is working okay. Any other ideas please?
Message posted on 07 Jul 2023 12:23 PM
Re: No sound on Qbox
Hi @Bumface1
Assume you have tried the different HDMI audio Output settings
- Normal
- Dolby Digital etc.
Message posted on 07 Jul 2023 12:25 PM
First double check the setting in :
Home - Settings - Setup - Audio Visual
Digital audio output HDMI
& only set to Dolby Digital or Dolby Digital + if your TV can handle it
If that is all OK, although normal TV may be working I suggest you try doing a power down restart of your TV.
We often find this helps some who loose sound
Message posted on 07 Jul 2023 12:33 PM
Ah, the old IT Crowd solution...switch it off and on again...and it worked! 😆
Thanks very much!
Message posted on 09 Jun 2025 07:22 PM
I've followed these instructions to the letter but when the Sky box has come back to life, I get some blurb about "accessibility on Sky Q," can't use the remote to click "skip and set up later" and the 1 and 3 button makes the remote flash two red lights at me and nothing else. Is our Sky Q box now completely unusable or can someone help please? 😳
Message posted on 09 Jun 2025 07:27 PM
hi @Purplejamo
This message seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only (so must have line of sight of the box)
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
Message posted on 09 Jun 2025 07:28 PM
@Purplejamo wrote:I've followed these instructions to the letter but when the Sky box has come back to life, I get some blurb about "accessibility on Sky Q," can't use the remote to click "skip and set up later" and the 1 and 3 button makes the remote flash two red lights at me and nothing else. Is our Sky Q box now completely unusable or can someone help please? 😳
Hi @Purplejamo I would reset your remote by holding down 7 & 9 until the LED flashes 4 times. Make sure the box is in sight because the remote will now be in IR mode. Once you get in try the 1 & 3 again.
Message posted on 09 Jun 2025 07:29 PM
Sky have suggested the following...
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen "Skip & set up later"
- Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
