Discussion topic: How can I change my box. I want hdr
This message was authored by: Crickt+Fan
Hi,
I have just changed my tv. I now have hdr but my sky box hasn't got hdr. I need to change it for a later version. How can I do this?
Re: How can I change my box. I want hdr
@Crickt+Fan wrote:
Hi,
hi @Crickt+Fan
You will need to call, I am afraid & unfortunately they usually charge an upgrade fee of around £99
BTW If you do upgrade, when doing the swap remember to take the Viewing card out of the box
Also note that some 2TB HDR boxes have a separate power supply so make sure you check the delivery box in case it is one of these
