Discussion topic: No sky satellite
This message was authored by: Louise+Tennant
No sky satellite
I want to book an engineer
Re: No sky satellite
Work through the online help flow below and if that guidance doesn't fix your issue, it will allow you to book an engineer:
https://www.sky.com/help/articles/sky-tv-engineer-visits
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Hi @Louise+Tennant
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue.
If it is no Satellite signal Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
