Discussion topic: No sjy
Message posted on 19 May 2025 05:06 PM
No sjy
Sky q box and ghost boxes not working pulled plug out for
Message posted on 19 May 2025 05:32 PM
Re: No sjy
Your post appears unfinished and by ghost boxes I presume you mean mini boxes?
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
