5
This discussion topic has been answered Discussion topic: Viewing card no longer active
This message was authored by: Aegris
I've had Sky Q since January with no real issues so far, but I'm after turning the TV on today and was met with the message "Your viewing card is no longer active" and can't watch anything either live or recorded.
I was watching TV just fine last night and turned the box off as normal. Weirdly I got a text this morning around 10am from Sky with the following message:
"We're extremely sorry if you experienced issues with your Sky Q services recently. These issues have been fixed. If you're still having trouble, please switch off your box at the mains for 30 seconds, then back on. For mini box issues, also reboot the main box."
Wasn't sure what that was about because I hadn't been experiencing issues and assumed it was a mass message about something else, but could it be related to this?
I've taken the card out and reinserted it, paired the card via the system info/setup menu and restarted the box by disconnecting it from the mains but still getting the same error message.
Avatar for Aegris
Level 2 icon
This message was authored by: Aegris Answer
Re: Viewing card no longer active
Thanks @TonyG5 @Laing1 @Addie15 for the replies - I've rectified the issue in a roundabout way:
When the Sky Q box was being installed, the engineer asked if I'd been sent a new viewing card which I hadn't at that point, but he said it would work fine with the existing card from the Sky+HD box being replaced.
About a week after the box was installed I received a new viewing card in the post - the wording on it made it sound like it should've arrived before the engineer, so I contacted Sky and they said I can just continue to use the old viewing card as the new one wouldn't be enabled and there was probably no need to hang onto it.
Luckily I'm a hoarder and kept it anyway! I figured it was worth a try to swap in the new card, went through the pairing procedure and it started working straight away. Tried it yesterday and it's still working today so fingers crossed it stays that way. Still baffled as to how/why the other one would just stop working out of the blue 4 months later though.
This message was authored by: TonyG5
The official Sky message you received is relevant. Let’s dive in on some potential solutions:
  • Complete advice from Sky as per official message. (I appreciate you have done this). Remember to wait at least 5 minutes for services to return.
  • Log into your Sky account online and check your billing and subscription status.
  • Check the status of the Sky Q box in the menu system. It’s under settings. You should confirm you have a tick against satellite signal and network connection.
  • Check service status for Sky on your area. Here is the link:
    Check your services | Service Status | Sky.com
@Aegris I have escalated this to sky
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
If you are using the Safari browser please make sure that Hide IP Address is not checked in order to see the chat bubble. If you are having trouble finding this to check the settings, use another browser such as Firefox, Chrome etc.
The link below explains how the escalation process works
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to @Aegris.
This message was authored by: lsteph0
Hi, we're still having the problem this morning, the main box says "please insert the viewing card face up".
We have reset the box as per on line advice but no change and followed all other instruction but with no luck.
The problem started Sunday afternoon and we called and got help to resolve it though the issue started again late evening.
Is there anything we can do to rectify this via on-line?
Avatar for Aegris
Level 2 icon
