Discussion topic: No sjy
This message was authored by: CoachHouse
No sjy
Sky q box and ghost boxes not working pulled plug out for
Re: No sjy
Your post appears unfinished and by ghost boxes I presume you mean mini boxes?
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
