Discussion topic: No signal
Message posted on 31 May 2025 11:17 AM
No signal
I had fibre broadband fitted yesterday which is working fine, but I have no satellite signal and cant get anyone out until thursday next week, i have done all the tests but nothing works
Message posted on 31 May 2025 11:25 AM
Re: No signal
Hi @Rebecca112
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
Message posted on 31 May 2025 11:27 AM
Re: No signal
Thursday next isn't too bad to be honest.
Check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight.
It’s worth noting that:
