Discussion topic: Problems with st signal from q box to mini boxes
Message posted on 31 May 2025 09:23 AM
Cannot get the q box to send satellite signal to mini boxes despite them saying connected to each other and also q box not loading recordings
Message posted on 31 May 2025 10:50 AM
Re: Problems with st signal from q box to mini boxes
Any errors messages about hard disk?
I suspect it could have failed. (As signals are cached there before being sent to minis)
I presume you've tried power cycling the main box?
Message posted on 31 May 2025 11:01 AM
Hi @Mickl1
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
