Discussion topic: No signal
Message posted on 26 May 2024 02:46 PM
No signal
My sky mini box is no getting signal. It's said it's connected to the main box. I've reset it a couple of times but still not working
Message posted on 26 May 2024 03:46 PM
Re: No signal
Hi @Crakey123
Reboot the mini as above.
