Discussion topic: Lagging on every channel
This message was authored by: Kelliesmith1
All tvs in house lagging for past 5 days today it's unwatchable
Re: Lagging on every channel
Hi @Kelliesmith1
Try a Reset Settings in the main Q box hidden menu.
