Discussion topic: No signal
This message was authored by: Kirstylou94
No signal
I have been having no signal satalite and techicnal issue with this channel for ages someone come out and still getting it done everything possible. Yet I still been charged my full bill!!!
This message was authored by: bob1234
Re: No signal
@Kirstylou94Which channel, if there are a few your dish could have moved out of alignment and you will need to get Sky to come out and fix it.
Re: No signal
Do you have your own satellite dish? If so, have you spoken to Sky to let them know you're still having signal problems?
This message was authored by: Melaniec30
Re: No signal
hi there I have just cancelled an engineer visit for thurs 18th jul thinking my signal problem was resolved but have noticed it is only some channels so can I reschedule the appointment please
Re: No signal
@Melaniec30
We are customers here like yourself. You'll need to contact Sky again to re-book an engineer.
In the meantime, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
