Discussion topic: No signal
This message was authored by: Belinda
No signal
No sky signal. Done everything obvious. Tv works fine with Netflix and sky recordings
what can be the problem
Re: No signal
@Belinda
”No signal” tends to be a message from your TV. A “no satellite signal” message relates to your Sky box. Take a look at the troubleshooting on the appropriate section of this link.
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
You may then need to contact Sky and arrange for an engineer to check the alignment of your dish. Be aware that if you’re on a communal dish system you’ll have to contact your landlord or building management company rather than Sky.
