2
This discussion topic has been answered Discussion topic: No signal check the external input or select another input using the input button
This message was authored by: MueS
When switching from Netflix back to TV the  message appeared- No signal check the external input or select another input using the input button - any ideas?
Avatar for MueS
This message was authored by: MueS Answer
Re: No signal check the external input or select another input using the input button
Thank you, all sorted now. Managed to find the right help guide on Sky App - reset box.
Hi @MueS
This is a message from your TV set.
Is the Q box on with green led and are you sure that your TV set is switched to the correct HDMI input to which your Q box is connected?
Avatar for MueS
