This discussion topic has been answered Discussion topic: No signal check the external input or select another input using the input button
Message posted on 07 Oct 2023 08:53 AM
When switching from Netflix back to TV the message appeared- No signal check the external input or select another input using the input button - any ideas?
Message posted on 07 Oct 2023 10:08 AM
Thank you, all sorted now. Managed to find the right help guide on Sky App - reset box.
Message posted on 07 Oct 2023 10:03 AM
Re: No signal check the external input or select another input using the input button
Hi @MueS
This is a message from your TV set.
Is the Q box on with green led and are you sure that your TV set is switched to the correct HDMI input to which your Q box is connected?
