Discussion topic: Not connecting to router
This message was authored by: Carole1370
Sky box not connecting to router
Re: Not connecting to router
Hi @Carole1370
Assume this is your main Q box and not a mini?
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
