Discussion topic: No signal at night
Message posted on 18 Mar 2025 10:20 PM
No signal at night
I have a number of channels that I am unable to watch at night. Some are saying the channel is affected by a problem with my signal others are pixelated. However these channels are fine in the day. Is this a fault with my dish and has anyone else had the same issue
Message posted on 19 Mar 2025 05:04 AM
Re: No signal at night
@SharonW25
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
