Discussion topic: No satellite signal
Message posted on 31 Jul 2025 10:10 PM
No satellite signal
My tv says it has no satellite signal on my sky mini but my main sky q box works
Message posted on 01 Aug 2025 09:13 AM
Re: No satellite signal
hi @Morsey1
The mini gets it's signal via a tuner in the main box, even though that may be working itself :
The first thing is to restart your main SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Once the main box is restarted do the same power down on each of your mini boxes.
