Discussion topic: No satellite signal
Message posted on 13 Jan 2025 06:10 PM
No satellite signal
Message on screen No satellite signal.
Tried restarting it
Message posted on 13 Jan 2025 06:34 PM
Re: No satellite signal
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
Message posted on 13 Jan 2025 06:37 PM
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in this link
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
It’s also worth mentioning that a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
