Discussion topic: No satellite signal
Message posted on 08 Aug 2024 11:18 AM
No satellite signal
No satellite signal. I have checked the box etc
Re: No satellite signal
@Charlotte2390
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with you building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
