Discussion topic: No satellite signal
Message posted on 18 Jul 2024 10:13 PM
No satellite signal
No satellite signal
Message posted on 18 Jul 2024 10:17 PM
Re: No satellite signal
No sattelite signal
Message posted on 18 Jul 2024 10:34 PM
Message posted on 19 Jul 2024 05:30 AM
@Marie46
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in the link provided by @Mark39
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
