2
This discussion topic has been answered Discussion topic: Catch up not working
This message was authored by: Sande
Hi I'm trying to watch a programme on catch up and it's telling me a need to upgrade to HD I've had this problem before I used to just change format to standard and it sorted the problem but it's not letting me do it this way no more??
Re: Catch up not working
Hi @Sande
Its best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to be done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
Hi @Sande
Avatar for Sande
Ahh brilliant thank you 👍
