3
This discussion topic has been answered Discussion topic: No satellite signal
This message was authored by: Kevdev19
No satellite signal
Recording works but no live tv,saying no satellite signal
Re: No satellite signal
@Kevdev19
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
@Kevdev19  This doesn't sound like a Sky Go issue, which box are you seeing this on?   Sky+HD or Sky Q?
Avatar for Kevdev19
Yes it's a sky q box
@Kevdev19
Answered - Go to Answer
