4
This discussion topic has been answered Discussion topic: No satellite signal
This message was authored by: Mildaa
No satellite signal
Looks like my tv channels most of them not working like bbc ant etc.. does that have something to do with the storm?
Re: No satellite signal
@Mildaa
If it persists after the storms pass and possibly a “no satellite signal” message is displayed, firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. After that look at the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
If the wind has moved your dish, yes.
@Mildaa
This message was authored by: Bernie25
I will need an engineer to check my own satellite dish up on d roof
@Bernie25
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels and
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
There will be many others in the same boat after the storm so expect likely delays in getting through to an agent and the availability of an engineer.
edit: if your dish is on the roof this will cause extra problems/delays.
Answered - Go to Answer
