5
This discussion topic has been answered Discussion topic: No satellite signal message on mini box
This message was authored by: ARCooper
All connections on main SkyQ box are ticks, as are those on mini box.
reactivate hasn't worked.
main box says satellite signal strength is very good.
cant watch tv on mini box at all?
Avatar for ARCooper
This message was authored by: ARCooper Answer
Re: No satellite signal message on mini box
I have performed a hard reset on the main SkyQ box at the expense of losing recordings etc but it seems to have cured the issues.
This is the second time I have had to do this as a last resort. Is this an indication that the hard drive may be about to fail?
Hi @ARCooper
Reboot the mini as above.
Avatar for ARCooper
Thank you. I have trued all of the actions suggested but no luck.
The system as it is today has been working perfectly since it was installed, so no idea why wifi would be causing it?
What happened when you tried the Network reset on the mini @ARCooper
Avatar for ARCooper
I have now discovered the recordings on my main Sky Q box have disappeared and all I get is the Please wait scrolling circle.
Also,  scheduled recordings gone too.
Seems like problems with both main and mini boxes now.
Avatar for ARCooper
