3
This discussion topic has been answered Discussion topic: No operation performed for a long time
This message was authored by: Janis+rice
Why do I get this message along the top of my screen....There was no operation performed for a long time,shut down? Then I get three options...yes/no/disable but my remote doesn't respond to any choices....and yes, I have disabed eco/standby mode. It's so annoying that I end up switching off and starting again, any advice appreciated thanks
This message was authored by: nigea99 Answer
Re: No operation performed for a long time
hi @Janis+rice
this will be your TV & is not your SKY box.
This often happens because when you use a SKY box, you are interacting less with the TV itself.
Often just using the volume up/down buttons will dismiss the message - if not you will need to use the TV's own remote
hi @Janis+rice
@Janis+rice
You may be able to permanently adjust this behaviour by accessing the television settings using the TV remote.  As @nigea99 indicates, it's not the Q box generating the message, and the Q remote won't be able to modify it.
Avatar for Janis+rice
Thankyou for your replies, I'll give it a try with tv remote...although I'm useless with tech issues!..🤞
