Discussion topic: No network connection
This message was authored by: Steve26dt309
my SKY Q box seems to disconnect from the internet very often, with no loss of internet with other devices, sometimes switching on the SKY Q box it says no internet connection, and I go through the reset procceedure to get it back on, then occassionaly whilst watching something it says streaming unavailable at the moment and the SKY Q box has disconnected from the internet again and I have to go through the reset procceedure again missing half the program that I was watching. ( football matches on the 'RED' button) HELP PLEASE anybody??
Re: No network connection
Hi @Steve26dt309
Avatar for Steve26dt309
Have tried full rset on router, and sky Q box, but to no avail, it is still disconnecting from the internet although other devices in the same room are still connected to the internet, ie phones and tablets, it's only the sky Q box that's diconnecting or losing the internet
Who is your broadband supplier @Steve26dt309
This message was authored by: ducky79
I'm having the exact same issue. All of a sudden the wifi dropped out, did a reset and still wouldn't connect, then as I was sat looking at the setup page you could see it all ticks, the a x then ticks. Attempted a software update but that doesn't seem to be working. Has been fine for months. No issues at all. And now this. Any help appreciated.
internet provider is BT
