Discussion topic: No mini box connection
This message was authored by: Gordoninlytham
All mini boxes stopped working
Can't watch recordings on sky q box
Re: No mini box connection
Try a power cycle on the main box but sounds like the hard drive may have failed.
You'll need to call Sky to arrange a replacement if so.
Hi @Gordoninlytham
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
