Discussion topic: Insert sky viewing card
Message posted on 25 Dec 2025 02:27 PM
Can't watch any Chanel's. Says insert sky viewing card. I have taken it out and wiped it, switched off at the wall. Also done a full factory reset
Message posted on 25 Dec 2025 03:18 PM
Re: Insert sky viewing card
Hi @Lisa448
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
