Discussion topic: No internet connection
Message posted on 20 Oct 2025 03:18 PM
Tv is showing no internet connection. Just dropped out for no reason whilst watching tv. I've tried reboooting everything many times but keeps coming up connection unsuccessful. I've tried using diagnostic tool on web page and it says everything ok. Wi fo on my phone is fine but no connection on TV - what do I do next ?
Message posted on 20 Oct 2025 03:43 PM
Re: No internet connection
Hi @ScottS2
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 12 Apr 2026 06:02 PM
Still saying no connection and asking to press WPS button which doesn't do anything .
