Discussion topic: No internet connection
This message was authored by: ScottS2
Tv is showing no internet connection. Just dropped out for no reason whilst watching tv. I've tried reboooting everything many times but keeps coming up connection unsuccessful. I've tried using diagnostic tool on web page and it says everything ok. Wi fo on my phone is fine  but no connection on TV - what do I do next ?
Re: No internet connection
Hi @ScottS2
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
This message was authored by: rsf1319
Still saying no connection and asking to press WPS button which doesn't do anything .
