Discussion topic: No internet connection
Message posted on 12 Nov 2024 08:55 PM
Continually getting a no internet connection on Sky q box. Everything else works, TV, Alexa, phones, iPads, computers etc. Usually I reboot the router and it comes back. But over the last week or so that's not working consistently. So I've had to resort to rebooting the sky box. That clears the problem as well, at least for a day or so but that clearly is not normal. Anyone have an tips or is it time after 40+ years to tell sky to do one. Have to stress I have other issues with service levels that considering the cost I feel sky should do more to fix. I'm not prepared to buy a new box.
Message posted on 12 Nov 2024 08:57 PM
Re: No internet connection
Hi @Balaclava
Try completly resetting your connection.
Message posted on 12 Nov 2024 09:01 PM
Thanks but been there done that. This is a long standing issue which has increased in frequency. It shouldn't be this inconvenient or inconsistent
