Discussion topic: No internet connection to sky q box
This message was authored by: Mk_24
I've followed all the steps using settings, I've knocked TV and internet box on and off. I've checked the signal. All other devices are connected. Just the sky box not connected.can anyone help?
Re: No internet connection to sky q box
Hi @Mk_24
Avatar for Mk_24
Thank you. I've tried everything. I spoke with a technician and an engineer is calling out tomorrow.
